Old 09-11-2006, 09:58 AM
xlr8or's Avatar
xlr8or xlr8or is offline
When checking voltage leaks on the wires in the dark make sure you check the coil wire as well. I had a coil wire come loose in the coil tower and basically baked the tower to the point that it was shorting out on the mounting surface.
