Old 09-12-2006, 04:40 AM
Cobra.au's Avatar
Cobra.au Cobra.au is offline
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Default Cobra.au Side Pipe Build
Hi guy's
I thought I might start a thread on the construction of my side pipes as it seems a pretty hot topic at the moment.
I will up date with pic's as the pipes go through the build process I should have most of the components by the end of the week but to give you an over view the material list is as follows keeping in mind they are designed for my supercharged 408 stroker
2" primaries
3 1/2 collector
4 1/2" outer shell
4" high flow metal cats (200 cell)
3" straight through perforated tube
here are the flanges I milled up from 10mm snow ground plate
Here are a couple of pic's of the Cats
And a look inside
Stay tuned for more info
Craig W
Central Coast NSW
