Old 09-12-2006, 11:11 PM
Cobra.au's Avatar
Cobra.au Cobra.au is offline
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
I will be making the primaries out of steel as this is the most heat effected part of the system and from the collector back out of 316 stainless because try sourcing 4 1/2" tube in any type of material. I was just lucky to know a guy who knows a guy who had a mill run of this odd size done and it was perfect to slip a 4" cat into with an air gap so there will be no discoloration later on from heat.
Once the pipes are finished they will be Jet Hot coated.
Stay Tuned
Craig W
Central Coast NSW
