I think that George at Python has his front and rear end tested and engineered so that it complied with ADR's I don't think that it was that expensive when you consider the price of a build. Problems do then arise if they go out of business, however if Ian was the only provider of these items then he would have the market cornered. I like the way the Leeroy has done his exhaust and considered doing it myself. The major problems is when it gets to the rear end and the exhaust has to go under the suspension which causes clearance issues. If you run active side pipes it is not a problem. I have recently block off my side pipes and past them back under the car and out. Much better to drive however I had to wind up the suspension to stop it dragging along the ground. I just think that part of the chassis has not been thought out that well. I intend to build a 'quieter' set of pipes that will be active however then there are legality problems.
steve
