Old 09-13-2006, 10:47 PM
bobt427 bobt427 is offline
Cobra Make, Engine: FFR 390FE
With the 7/8" master I had barely moved the slave fare enough to relase the clutch. The 1" master is the one you want. Wilwood part#260-3378 this one comes in a kit with the resivors. It will bolt up the same as the master you already have.
I don't no if you no ,but the 1959 ford truck that uses the slave has 1-1/8" master.
