Old 09-14-2006, 12:12 PM
Philip Messer Philip Messer is offline
Cobra Make, Engine: Backdraft #101, 392 Ford Motor
Talking Fixed the stick!
Same throttle sticking problem with BDR #101. I inserted a copper tubing sleeve (5/8-in diameter and ablout 3 inches long) between the two concentric springs that tension the throttel arm on the carb. This prevented the springs from getting interlocked. I also worked powdered graphic into the throttle cable. No problems since!
