For the 26 spline disk I have asked for a disk from a '79 Trans Am with a 400 in it. It used a T-10 which also has 26 splines and is an 11" disk. Then just use the pressure plate for an FE. I like to use the McLeod spacer instead of the shortened input shaft because it puts the shifter closer to where it was on an original Cobra.
