Old 09-14-2006, 03:48 PM
COBRA406 COBRA406 is offline
Cobra Make, Engine: MIDSTATES, 408C
Default Midstates 427 Cobra partially finished roller For Sale
I have a partially finished roller with engine/trans installed, about
75% complete. Car is a roller with suspension, brakes, fuel tank
and lines run and fitted. Features include:
ľ Mustang II tubular front suspension with GM metric calibers, poly rack and suspension bushings.
ľ Completely rebuilt or new parts. 9" Lincoln Versailles rear with 3:50 posi unit rebuilt.
ľ Carrera front coilovers and Aldan rear coilovers completely adjustable front and back.
ľ 400 Ford Cleveland based M block completely rebuilt and balanced.
ľ .030 over on block with Speedpro forged pistons with moly rings.
ľ Crank.010/.010 with peened rods with ARP bolts.
ľ Ford Motorsports cam 536 lift, 290 duration with Rhodes lifters.
ľ 1970 351C 4V closed chambered heads with stainless 2.19 int and 1.71 exh valves with 3 angle valve job and Crane double springs and retainers.
ľ Crane roller lifters and stud kit.
ľ New heat treated pushrods with guideplates.
ľ Motorsports valve covers.
ľ Aluminum hi volume water pump.
ľ Included are a new Mallory Unilite distributor and controller and coil.
ľ 8MM wires.
ľ Resurfaced flywheel with new starter gear.
ľ Gear reduction starter and 140A alternator.
ľ Centerforce clutch and pp.
ľ Lakewood scattershield.
ľ Image wheels and BFG's mounted and on car.
ľ Completely rebuilt toploader with Hurst shifter and reversed original style shifter.
ľ New driveshaft with yokes and new joints. Balanced, not installed.
ľ Body mounted with doors, hood, trunk and windshield installed.
ľ All latches included but not installed.
ľ Lucas light package installed. Wiring harness installed and run to locations. Ron Francis harness and instructions.
ľ Dash and Ididit column installed.
ľ Borgeson steering joints.
ľ Complete interior with seats included but not installed.
ľ Roll bar installed.
ľ All appropriate hardware included.
ľ Heater mounted under dash.
ľ Lucas wipers installed; not wired.
ľ All parts including ceramic coated side pipes/headers included.
This car was purchased by me from Bob Kallio at Midstates in 1994. I have
lost my third garage stall with this move and don't have the space or time to
finish. Car is in indoor storage.
Price: $17,500 firm. Car has been thoroughly researched and only the best components included.
970-292-8086 home
970-566-0311 cell
Questions: cobrabobby@comcast.net
