Old 09-14-2006, 10:30 PM
GeorgiaSnake's Avatar
GeorgiaSnake GeorgiaSnake is offline
Cobra Make, Engine: Sold - Unique FIA - SA 396 Stroker
Default Revised Unique FIA Price
It's time for another project (may get back into racing) - so my Unique FIA is For Sale
Well sorted (2,600 miles) Unique FIA (ID#2899420, manufactured in 2003) powered by a SA 396 stroker running through a wide ratio toploader to a 3:31limited slip Jaguar differential. Team III 16” wheels (8” fronts, 10” rears), B.F. Goodrich T/A’s (245/50/16 fronts, 265/50/16 rears). PPG Mercedes Brilliant Silver. The car is registered in Georgia as a 1964 Cobra FIA. Build pictures and receipts are available. See my Gallery for pictures.
$41,000
Still the same outstanding car just revised the price to reflect the current market - now available for $38,000 May consider a project CSR Racer / S2000 (Lola, Tiga etc.) car as partial trade.
Unique Deluxe Pallet plus:
Tonneau Cover, Aluminum Foot Box Heat Shields with Thermite Insulation, Battery Disconnect, Driveshaft Safety Loop, Moroso Remote Oil Filter
Hurst Indy Shifter (relocates shifter to proper FIA position), 5 Point Harness (both sides), Heater (no defroster cuts – have the aluminum vent covers), 3 Raydyot Mirrors, Seat Track (driver’s side), Instrument Upgrade (Stewart – Warner large face), Wind Wings / Sun Visors, 15” Leather Steering Wheel, Moroso Inline Filler, Differential Cross Brace, Oil Cooler w/ Stainless Hoses, Canton Expansion Tank, Optima Battery, 16” Puller Fan (twin pushers included but not mounted), Aluminum Shrouding for Oil Cooler / Radiator
MSD Ignition, Indoor Car Cover and Garage Caddies
Engine Build Sheet:
351 W Block – E3AE-6015-18, Scat #8160 3.850” Steel Stroker w One Piece Seal, Ford D60E Forged Rods w ARP Bolts, Engine Tech – Hypereutectic Pistons 9.8:1 Compression, Hastings Molly Rings, Engine Tech Bearings, Elgin E961P Solid Lifter Cam (cam card available), Melling High Volume Oil Pump, Canton 8 Qt. 15-660 Pan, Edelbrock Performer RPM Aluminum Fully Ported and Polished Heads, Edelbrock Performer RPM Port Matched Manifold, Motorsports Roller Rockers, Motorsports 8.5” Heat Treated Pushrods, Holly 3310 750 CFM with Choke Removed and Quick Change Spring Kit (assorted springs and jets included), Centrifugal Advance Electronic Distributor, Carter High Volume Mechanical Fuel Pump, Aluminum High Volume Water Pump, March Pulleys, Aluminum Flywheel, Ram 11” Power Grip Street Strip Clutch (new less than 200 miles), Lakewood Blow Proof Bellhousing.
If you are looking for a very nice, fast, rock solid, dependable Unique FIA car this is it.
Sold the Unique - Bought a Porsche TT - Sold the TT - Bought a truck
