Another problem is the bulbs loosing contact at the socket. Make sure the bulbs are properly seated. You may want to use a little electrical tape around the bulbs base to cause a tighter fit. Mine did the same thing as yours until I taped them. No problems since.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
