Dynos are a great thing, but I think we all tend to place too much stock in the numbers and not enough in how the car actually runs. The post about exhausts and IRS robbing power are dead-on. Research on this site and elsewhere and you'll find that side exhausts, which we all love and believe to be much more efficient than an under-car setup, can actually be a detriment if not carefully designed,
As far as your numbers' I can only offer those of my Beck Lister for comparison, The car has a Corvette IRS, which does rob power vs. a live axle because of the multiple u-joints, the angle of the driveshafts, etc. It also has side exhausts. The builder dynoed the engine on an engine dyno--542 hp/ 508 ft-lbs.
A year or so later, after I got the car together, I had it dyno-tuned on a chassis dyno. I don't have the numbers in front of me, but I think it made around 417 hp and 395 ft-lbs.--losses of close to 25%. I had been expecting about 15%, which the figure you often see, so I was pretty shocked--until I drove it. It ran like a motherf_____. As I said, I think the numbers are much less important than ensuring the car's tuned right. Numbers may give you bragging rights, but they won't keep you from getting waxed by the kid in the chipped Subie WRX.
Get the car tuned, get it to a dragstrip, then decide if it's making adequate power (and getting it to the ground) or not.
