09-17-2006, 06:41 AM
OH
Cobra Make, Engine: CSX4000, 427
Originally Posted by DAVID GAGNARD
Cars 1 thru 3, all 05 Mustang GTs, all 3 bone stock except for maybe a K & N air filter, that's it..........all 3 made from 262rwhp to 267 rwhp, they are adveritsed at 300 flywheel hp!!!!!!!!!!!! that's from 13% to 11% driveline loss, I think either Ford "fudged" those #s a little or else the driveline is very efficent.............
Pull # 3; operator told him to start in second gear and do the pull in 3rd gear, again, have NO CLUE why they would do it this way, but they did, I was standing near the rear of the car watching the driveline, he was running WAY,WAY rich by now, both exhaust pipes looked like a diesel truck going up a steep slope loaded down,he made 272 rwhp!!!!!!!!!!!!! when he shut it down and the operatpr showed him the #s and the printout, he was pi$$ed and told them to unhook the car and guide him down......they had a few words and he left, was only charged for 2 runs.........
Later talking to the operator he told me the "average" loss he has seen for late model cars with a stick shift was 15%........
The old Mach I was running a 4 speed toploader and 9" rear end with 3.89 rear gears, he had on a set of drag radials and as I was watching the rear of the car of his last pull, I did not see any signs of his tires slipping or spinning on the drums.........he had a very badly tuned motor, no doubt, but still thought he should have made from 350 to 375 hp at the wheels, he was about 100hp off............
I was very surprised at the low % of loss for the 05 GTs and very suprised at the high? % loss for a 428 Cobra Jet motor, sure thought it would have done a lot better.............
I don't think that you can really make any statement about driveline loss only with information from a chassis dyno. I would think that you would have to also dyno the same engine on a stand, using the same dyno, with the same air intake set-up and exhaust system to get a real % driveline loss, otherwise you're just guessing.
Originally Posted by Excaliber
That Mach 1 pulled in 3rd gear, again, if your not in a 1 to 1 gear ratio you can throw out the results.
I don't think it really matters, as the dyno knows the overall gearing from the engine rpm and wheel speed, and I doubt there would be a large percentage loss in the transmission using 3rd gear instead of 4th. Anybody know what the hp loss would be ? Maybe 5-10 hp?
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
