Old 09-17-2006, 07:06 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Jac Mac
Have you actually checked the bore/stroke size of both blocks. The 72 is more likely to be a 390, remember most blocks have 352 cast on the front regardless of actual size. 390 started in 1961, so you might get a pleasant surprise!
If the '63 is a 390 as well, I've heard that the passenger 390's from the '60's generally have the thickest walls, and have a better chance to being bored out to 4.13", same as 428, so the '63 block may be a good one. You won't know until you measure the bores of the block, and have the walls sonic tested.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
