Old 09-17-2006, 04:15 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make & Engine: ERA 427SC w/427so, ERA GT #2002
Pat:
Thanks for the suggestion. That's was my initial thought, so I removed the check valves, soaked and blew them out in each direction. I checked for flow in one direction and checked that the valves closed in the other direction. Something I didn't mention was there was an audible high-frequency vibration on the rear bulkhead where the check valves are mounted. This is intermittment and they aren't even made by Lucas! My first thought was that the right check valve was not closing, allowing fuel from the left pump when only it was operating to flow under low pressure to the right tank, thus starving the carburetor. The question remains: Why does the right tank empty while no fuel is pumped from the left tank when both pumps are operating?
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
