Old 09-18-2006, 05:43 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make & Engine: ERA 427SC w/427so, ERA GT #2002
Bob:
Thanks for the suggestion. I'll give the "stiff-wire" solution a try. This is an early car--#2002--so a kinked hose may be the problem. It's worth giving easy fixes a try first. Beats removing the tank. Ted did say that foam used in these early tanks was "bullet proof", so the problem is unlikely foam degradation.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
