Originally Posted by mobilenuke
I thought you had to turn the oilpump shaft counterclockwise?
Mobilenuke is right; by spinning the
oil pump clockwise, you had no
oil in the engine galleries, bearings,
oil filter, etc. and still may not. Pull the distributor and spin the oil pump counterclockwise. You should feel substantial pressure using a 1/2" drill. Can't say how your bearings are...
Best of luck,
Dan
