David, thanks for the info. I am aware of the larger journals in the 351W and the HV pump generating higher temps. I just thought I was well in the safe range. Sounds like our 351W engines run comparable temps. I am going to check the temps next time with the infrared temp gun. My sender is in the pan - top of the left side kick out to be exact. It is about time for me to rebuild the motor. I am going to talk with the engine builder and install an appropriate pump as well as check the baffling ect. A larger cooler is not a problem either. Thanks all for the info.
