H'mm
, Best ask the experts. ie exhaust place or muffler manufactuer.
If you are only concerned with passing rego then you could put cheap (even 2nd hand) big mufflers on and replace then with small ones after rego.
I'm no expert . A professional would probably tell you that the type of cat converters you use may also effect noise levels.
