Old 09-22-2006, 07:48 AM
Tom Decker Tom Decker is offline
Cobra Make, Engine: KMP 323
I did a #10 out let with a # 8 return. 120gph @ 7Psi bypass system. The problem you will need to address with a high HP/ high flow bypass system on a Kirkham is the small trap door system in the tank. With low fuel on a corner the fuel pump can easily empty the small trap door box. I cut open the fuel tank and increased the 4X4 trap door box to 12X12. While the tank is opened tig in new fittings with a new pickup and install a return to the rear corner.
Tom
Some Days You're The Big Dog Some Days You're Rusty Hydrant
