Old 09-22-2006, 11:09 AM
Tom Decker Tom Decker is offline
Cobra Make, Engine: KMP 323
My tank is a SS 42gal stock unit. I felt for durability, versitility (5psi to 75psi) and quietness that Aeromotive makes the finest pumps ava. I used the A1000 pump and the A1000 carb bypass with pre & post filters and the fuel computer. Your app would require the A1000 pump, pre & post filter and the A1000 injected bypass. You will have $1000 to $1500 in the system but it doesn't get any better. I mounted the pump under the car, in front of the pass rear tire to the outside of the frame. It takes a bunch of planning, time, hose fittings and Beer. As far as pick up placement, the stock location is fine. The trap is just to small. I installed the return fitting next to the out fitting in the stock location. I ran a internal SS line to the button rear conner of the tank from the return fitting.
Tom
Some Days You're The Big Dog Some Days You're Rusty Hydrant
