Old 09-23-2006, 07:52 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
The black can is called a "puke tank", and is used for blowby and oil forced out when roadracing. If you have the stamped steel "valley pan" under your intake, you can usually run a PCV valve in the rear location, as the valley pan keeps the oil under it for the most part so just blowby goes out the rear hole. If you're running hydraulic lifters, and especially hydraulic roller lifters where the valley pan won't fit, it's best to block that opening and run the PCV valve from a valve cover because too much oil is flying around in the valley area, causing the PCV valve to suck oil as well as blowby.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
