Old 06-23-2001, 07:28 PM
ACC427US ACC427US is offline
Default Shell Valley Body Install Problems
Put the body on today. At the wheels, The right side rear is 2" higher than the left. Both coil overs are set the same. Any idea why and what I can do about it?
The body sat on a body rack for maybe 4 years with some of it in the sun. COuld the rear and front nose settled some?
Anybody using a plywood shim under the body? I'm thinking of adding a 1 3/4" sheet of marine plywood under both the drivers side and passenger side to raise the body a little and maybe give it a little more strength.
