Old 06-23-2001, 09:14 PM
SVMCOBRA SVMCOBRA is offline
I am at work right now but can let you know tommorow. I don't know how far you are into you assembly process but I can relate to your problems. Seems like every time I go to install a part their is a problem. Is your body thin in alot of places ie: across the back of the car and the cowl area? Are all you cut outs allready done, if so I would like to know if the holes line up for the bumpers. One other problem I had with the body was the rear wheel radius was not the same on both sides in the back of the car, this was a major pain to correct.
