The holes for the bumpers line up side to side but the top bumper bolt lines up with the bottom mounting hole on the frame (both front and rear). As to how far along I am, I have all susp. mounted, motor in, radiator and hoses hooked up, body is on and aligned, gauges installed, headers and side pipes installed, lights installed, roll bar installed, gas tank installed, hood installed and trunk lid installed, steering column installed and clutch/brake pedal installed. I plan on pulling the body back off to install my transmission, run the brake lines and fuel lines. As to ordering you bumpers or any other stuff I went with Finishline, they we an absolute joy to deal with and cheaper on a lot of things. Plus if I had any problems(which I only had 1) it was resolved quickly (which is more than I can say about Shell Valley). You might want to call Shell Valley and request a new assembly manual as the new one is a whole lot better than the old one. Well enough rambling on, If you need any more help or info let me know.
Ray Hedden
