  #30 (permalink)
Old 09-27-2006, 12:27 AM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Originally Posted by Excaliber
...I'm not sure about the other FE's but standard piston to block deck spec on a side oiler was about .030 below deck. If the specs are similiar for other FE's thats a LOT of clearance (and no quench, which is of course a worthy goal). Custom pistons would likely be required to move the piston up in the bore more toward zero deck.
Quench can also be corrected by milling the deck. This may require milling the intake side of the heads to correct the intake match, depending on how much is removed from the deck.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
