why not put mufflers in your side pipes, have them cut and put in mufflers and then rewelded, if you have stright side pipes (without the glass packs) then you can have header collector mufflers put in, unless you cover the exit hole on the side of the car, it just won't look good, the slab side cars look good without side pipes, check them out before you buy
PapaJohn
