Old 09-27-2006, 06:40 AM
edhunter edhunter is offline
Cobra Make, Engine: FFR, 351W
f16n; yep, they're 5 lug, 4.5" centers... standard Ford spacing...
James; Wish I knew... if you pull one of you wheels off and lay a straightedge across the back of the rim, then measure to the mounting surface, that'll give you the backspace - the offset's would be the difference between 1/2 the total width of the rim minus the backspacing... it tells you how the wheel will fit in the well... At least I think that's right! Contact Olthoff (sp?) just north of charlotte, they should be able to tell you...
The spinners I got from TeamIII wheels... cost ~$330 shipped for the set of 4.
Original cost was around $240-250/ea. for the 17x9, $280-300/ea. for the 17x10.5 wheels IIRC...
ed
