  #21 (permalink)
Old 09-27-2006, 11:22 AM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
Hi James,
How hot does the floor get under your seat where the box is? Did you cover it with some sort of heat guard?
The floor stays cool. We've gone 450 miles + in a day without any heat problems at all. Everett Morrison supplied a thin, aluminized flexible heat barrier - kinda looks like fiberglass with a reflecting material adhered to one side. The reflective side faces the mufflers, and it's glued to an aluminum sheet which rests on the frame under the floor of the footboxes.
Did you do the cutting through the frame components to get it through?
The E-M has three outrigger supports. The factory relocated the center one to the front, and then put the notch there to accommodate the headpipe.
Tom
