[IMG]
[/IMG]
Here a wheel puller i made out of .250 thick steel 3.250 dia with a .375 fine thread bolt 4.00 long just transfered hole patter off wheel works great I work in a machineshop but you can make one with a little work and a saw
the steering wheel is held on with 6 flat head allen screws remove this to take wheel off make sure the aircraft nut on hub is tight. to remove hub to get to turn singals remove nut and use puller
HOPE this helps
ED
