Thread: Junk Yard
Old 09-27-2006, 04:40 PM
big-boss big-boss is offline
Cobra Make, Engine: KMP 498
These engines are a dime a dozen, almost. Here in CA every Pick a part has a dozen or so. 250 is about the rate with no core. The ones in the trucks usually have the right alt. brackets and more usable trinckets. Only bad thing is you can't for sure tell what they are until you take then apart. There are still alot of 428 cranks out there and good blocks. I got an old 65 ford PU two months ago for free. Turned out it had Low Riser Heads, Adj rockers, low riser intake and a 390 crank. I would have bet it was a 352 at first. I sold most of the stuff on Ebay already. Very fun, good luck.
