Thread: steering column
Old 09-27-2006, 09:07 PM
Trueoo7 Trueoo7 is offline
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
The center cap on mine was held on by three pices of two sided foam tape. It took awhile but I slipped a thin pocketknife under the cap and kept working it back and forth until I could get some movement. Just go slow and take your time, you'll get it.
As far as the column assembly, there is a muffler type clamp up under the dash that the column passes through that I suspect is loose. The plug that connects the blinkers to the dash wiring was folded up and wire tied to the clamp on mine, so it may be hard to recognize at first. The clamp is welded to the dash farme that runs under the dash. Theres also a clamp type holder in the engine compartment that has two set screws that could be tightened up too. Thats in clear view so it shouldn't be hard to find.
Good Luck
Trueoo7
Just as an afterthought, there are two, I don't want to say bearings in the sense of metal type but more like corrugated black cardboard that has little steel balls that act as bearings inside the outer column. They could be bad or disentigrating so look at that as well.
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
