Timhorr
Had the same problem with 12?, disappointing to see chassis 323 and they have not figured it out. I removed the tire and drum over the emergency brake, had to remove the caliper also. I did not know about mrmagoo method. You are right about one cable being too short. in the end my right side brake held the load, regardless of how much adjustment and iterations i got it to work but not perfect. The brake had to wear in a little but once it did it worked. I sent an email to Tony about this over a year ago, I thought they would have addressed it, BDR does not realize customer that have 40-50k to blow on the car may not have been a mechanic in a previous life.
