Old 09-29-2006, 07:25 PM
LMH's Avatar
LMH LMH is offline
It's a somewhat common problem with small blocks and the fix as I've been told is to replace the pin with one made for a Chevy. It's both larger and stronger. It tends to occur on small blocks that are using a HV oil pump.
That said, I don't know if FE's are subject to the same situation but it might be a fix for you anyway.
