Old 10-02-2006, 09:12 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Domi, there are several brake kits available for the front and rear of your car. Wilwood makes an excellent setup as well as many other companies. Do you have a price range you want to stay within. You also need to make sure you have a 9" and not an 8.8 rear. That makes a difference in what you order.
If you have a cooling problem when the car is in traffic or moving slow that is the electric fan not moving enough air. If you have a problem when running on the road at speed then the problem is radiator capacity. We Changed to Griffin aluminum radiators with a larger capacity years ago. We also changed from the old black magic electric fans to Zirgo. They work great and will cool up to 450hp with no problem.
Don
