Old 10-03-2006, 02:06 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Smile Not quite right.
I think Reg would have told you to remove the distributor and using an old dist with the gear removed and a cordless drill turning anti clockwise , pump up oil pressure without cranking the engine ( assuming this is a wet sump motor ). Yes its a little bit of work, but sfa compared to rebuilding due to premature bearing wear!
If you simply remove the distributor and crank the engine over you will never get oil pressure as the distributor drives the oil pump!
Jac Mac
