Old 10-05-2006, 12:26 AM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Originally Posted by Jac Mac
If there is one 'trick tip' that has come from racing over the last few years it would have to be the practice of cutting a vertical groove from the bottom to approx half way up on the left side [ looking from front to rear ] of each lifter bore so that a fine jet of pressure oil from the lifter gallery is directed onto each cam lobe /lifter...Comp Cams has a special tool & diagram of the process in the catalog.
Jac Mac
This is indeed an excellent tip; however, if your block isn't drilled for hydraulics or the hydraulic galleries are blocked off, there's no oil to be had in this area, only that which drips from the rockers. This is also true of the lifters with the hole in the face. In these cases, most oil getting to the cam and lifters is thrown up from the crank and rods, and that's a lot.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
