Keith,
Is this a vacuum opened secondary carburetor? Also you say it is soaking wet when you take the air cleaner off. Can you see gas dripping or coming from either end? If you have had a back fire or anything like that, unless your carb. has the blow by protection, you could possible have blown a power valve. The older Holly's were famous for this and I used to carry two or three all the time to put in when I was out and one blew.
After it set for a couple of days and you started it up, how did it run then? any black smoke or sputtering?
