Old 10-05-2006, 11:20 AM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
See DonC it depends on your engine. Long stroke with low end torque 428.
Engine has to be taken into consideration on rear end gear and trans gearing.
I do think a TKO600 with a .82 would work fine with my set up with 3.31 but I think it would be even better with 3.54s.
The engine you are building has alot to do with the gears you choose.
