Old 10-05-2006, 10:48 AM
xlr8or's Avatar
xlr8or xlr8or is offline
You should not be able to turn the cable from the speedo end if the car is not moving. If the gear on the cable does not spin on the cable then it's going to need a new driven gear. If you have a reverser hooked up to your speedo you might want to check that and make sure is spins freely and add some grease.
