Old 10-06-2006, 01:40 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Ron Going
Can someone tell me what the best gasket setup is when installing a "turkey pan". I'm sure you need a gasket on the intake manifold and then one between the carb and the cold air box. Just curious what others may have used to prevent vacuum leaks. Lastly, is there one cold air box that is better than the rest? Thanks for the help. Ron
I just used a couple of the standard carb base gaskets, that you should be able to buy at the local autoparts store, and sandwiched the turkey pan between the carb and intake , and also possibly a spacer.
I bought mine from Kirkham. However, It wouldn't fit on my friends 351W with the distributor. He got his from somewhere else, with a shortened front to clear the distributor
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
