  #28 (permalink)
Old 10-08-2006, 09:53 AM
jimmymac jimmymac is offline
Default Question
When you were driving? Did the motor over heat ? Use water Or any steam come out the tail pipe. Compressions far outweigh the pressure of the cooling system. So while driving you should have seen or had some signs. Over flow from the radiator? Compression entering the cooling system . Just a thought. Good Luck Jimmymac
