Thread: Track Alignment
Old 10-09-2006, 01:27 PM
tony martin tony martin is offline
Send a message via AIM to tony martin
Default Wa
Mac,
Race Track Set Up For Backdraft Roadster
Front
Lower Frt To Get -2 Degree Camber
Set Frt Toe In 1mm Each Side 2mm Total Toe In.
Rear
Set Rear Rt Ht To Have 1 Inch Measured On Chassis Higher At Rear Than The Frt.
Set Camber -1 1/2 To - 2 Degree Camber
Set Toe In 1 Mm Total
Start At 1.6 Bar Tire Pressure,cold, All Round.(road Rubber).
Should Build Up To Approx 2.2 Hot
Recomend U Get A Set Of Race Springs From Reg.
Sock It To Them!!:mecool:
Drive Safely,and Have Fun,
Regards,:d
mr lucky
