Old 10-09-2006, 02:35 PM
Philip Messer Philip Messer is offline
Cobra Make, Engine: Backdraft #101, 392 Ford Motor
I have recently replaced a radiator in BDR # 101. There are four bolts that fasten the radiator to the fiiberglass mounting. Just drain the radiator (drain plug on drivers side, engine side at bottom of radiator), disconnect the hoses, disconnect the dual fans (four bolts) and drop thru bottom, remove four radiator bolts and drop radiator down thru bottom. Actually, the fan assembly and radiator can be removed separately up through the top of the vehicle (but the tolerances are close and you might scratch your lovely paint!).
Reg has the aluminum radiator replacement in stock and there is only one replacment for your Backdraft. I am sure you could find some other replacement, but Reg has the like-kind replacement at a cost of $223.00. Have it FedExed by air--if by truck, it may take weeks!
Phil
