Wow,
I can't believe that someone builds a worse or more unsafe car than my builder does.
Sounds like my car times two. Had very similar problems when mine was "Finished" & took delivery.
Everything from the steering column brackets inclusive to the steering rack & tie rod ends were LOOSE!!! This on a vehicle that was delivered with a SAFTEY CERTIFICATE verifying it had been inspected & approved by a licensed mechanic (builders signature on certificate). I won't even mention the loose fuel line or all the shifter linkage bushings missing etc. etc. etc. etc.
Darn!! I said I wouldn't mention that.
I could go on forever but will not as I have decided to get on with it & fix/finish all unsatisfactory workmanship ( being somewhat generous using that term in this particular case) myself. At least that way I will not be endagering my grand childrens lives when they go for a ride with Poppa.
Craig
