Old 10-12-2006, 09:02 PM
hi-tech cobra's Avatar
hi-tech cobra hi-tech cobra is offline
Cobra Make, Engine: Hi-Tech
Default Topic: Tremec, toploader, G-Force or T-5 world class?
I also posted this on CSXinfo...
Which tranny should I get?
Car: Hi-Tech chassis/CSX fiberglass body
Engine: 347 eagle forged stroker
Chassis is already set up for toploader, I will need to notch the cross member if I go a different route.
I don't know the rear end ratio. Does anyone know what Hi-Tech used in their 9" set up?
I could go with a toploader and be done with it since the chassis is set up for it. Although I will probably regret not having the overdrive.
The T-5 world class is appealing because I'm not making crazy hp and it's less $ than a TKO. But will it hold up?
The Tremec TKO 600 would hold up, but I have heard it shifts like a bag of rocks.
The G-Force sounds good too. I just don't know much about it.
