True007,
I went and purchased some brackets today at Home depot to mount the fans as you said. I would also like to add a switch like you did (one supplied with finishline kit). How did you run your wiring? Did you wire the switch all the way to the battery or did you tap into a power source somewhere else?
Is there a trick to drilling hole in the dash for the switch to mount in. I dont want to mess up the vynel on the dash. I am guessing that you would cut a small "x" in the covering then start with a small bit and work up in size?
