  #1619 (permalink)
Old 10-13-2006, 07:04 AM
Ron61's Avatar
Ron61 Ron61 is offline
Tru,
I went for a drive yesterday to the pet store as I had to pick up some things and now I have a project. One of my fans isn't getting juice and it is in one of that cluster fu** of wires under the dash. The guy that originally wired it gave me a schematic of which wire went to the toggle switch and how they were ran. Right. Not a single dam wire is the color he said it was. The toggle switch has those dam white wires with the little numbers that I can't read at all on it and trying to see upside down under that dash is just murder. I did just go up front and find the power leads to the fans and connected them together and now they both run, but I am going to have to try to trace those leads out from under the dash and see where the connection came loose. He just spliced white leads to colored ones all over the car and kept no records of where the splices were or which color was connected to which white lead, and then shrink wrapped the dam wiring loom. I may wind up just running a new wire as it is impossible to get to the loom with the motor in. I am not a happy person but I can drive the car as both fans work the way I have it now and it has never even turned them on except in traffic on hot days or when I first shut the engine off after a long drive and it is hot. Want to come help me as I am sure you can get under that dash and read those little black numbers on the wires better than I can. FIRDAY THE 13th
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
