Old 10-13-2006, 08:02 PM
Burgs's Avatar
Burgs Burgs is offline
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Originally Posted by RedSabre
I am not sure I like the idea of taking off in gear as what if it doesn't release then I have to cut the engine to stop and find a way to push it back home. Not to mention will anything get missed up? Sure don't need to have any damage occur.[/size]
If it does not break it loose, cut the engine to stop as needed, and start it in gear again, to get it home. I don't see anything getting messed up, unless you run into something,... but it will break it loose. Make sure you have a long enough take off runway to goose it a few times if need be.
No, it's not the TO bearing. Can you see the fork move back and forth, as someone pushes the pedal? If yes, you should also see the TO bearing moving back and forth on the input shaft, not as much as the fork, but you should be able to see it move.
