Old 10-14-2006, 04:01 PM
Mark Brye's Avatar
Mark Brye Mark Brye is offline
Cobra Make, Engine: BDR354/FMS392
I think the easiest route is for me to wire the pushers to the existing fans. Does anyone know if the factory BDR fan wiring can handle another two fans on the circuit?
I was also looking at the BDR wiring diagram and it looks like the switch on the dash is supplying a switched ground to the fan relay to open or close the relay contacts for the power. Is this correct?
Is there a spare power source in the fuse panel behind the kick panel that I could possibly run a power lead to if I install my own switch?
Sorry for so many questions!
When I am finished, I will write up how I accomplished the task.
