We are currently having these produced, if you want a set of the 8 let me know. They will be around $80- set.
Andrew - you need the 8 units, including the engine check lgt.
Mike - You do not need the body module, the engine check light wire comes from the ECU & goes to the Diag plug. It is the yellow wire.
Ian
